I have been searching and reading post on fuel gauges for the past couple of weeks and have not found a answer to my question. Where or how should the tank sending unit be grounded? I have what I think is a James Duff 23 gallon tank (po install). Fuel guage stopped working a while back and after working on it some I found no ground or any evidence of a ground existing. Do these have to be grounded to work? It appears the sending unit and the tank are both fairly new, I know this does not mean that the sending unit can't be bad. I can't remove the wire from the sending unit so I cut it as close to the sending unit I could and put it to ground and my guage moved. Is the a sure thing that the sending unit is bad or do I need a ground. Either way it looks as if my tank is coming down. Also this is my only tank, so no switch.
