Another fuel guage question
STICK76
Fitzgerald, GA
When I fill my main tank, it will only register 3/4 full. I can drive for a good while when I go past empty. I would much rather it show full and know when I get to empty it is time to fill up. How do I fix this problem?
Thanks,
Stick
wildbill
Old Bronco Guy
:p :p :p You mite trying adjusting the float as it sounds like it is to low or it mite be a bad float they do leak sometimes good luck.;D ;D ;D Bill :cool: %) :p
74bronc
There is a little adjustment screw on the back of the instrument cluster voltage regulator. Fill the tank and adjust that in tiny increments until the gauge reads full. Mine reads the same as yours but I am too lazy to crawl under the dash of my own rig and adjust it for myself! I have fixed a few EB gas guage problems this way. Not exactly sure what affect it has on the other gauges, but it works for the gas gauge.
tbruz
fuel gauge adjustment
I had the same problem with my 76 and the guage was off exactly the same for both tanks; i.e. full tank = 3/4 reading on gauge..I had tested the float the wiring and the empty/full resistance readings so I knew it was a needle position problem.
You need to remove the fuel gauge from the instrument cluster(it can be done from under the dash if you have small hands) once removed from the cluster the back of the fuel gauge comes off(2 screws) exposing a needle adjustment screw....make sure you have a full tank; electrically hook up the removed fuel gauge and let it hang under the dash. Now adjust the needle accordingly...
reverse the process and you're done.
regards,
TonyB
