So, a little back story. Have duel stock tanks with stock brass fuel tank selector on my carburetor '76 with electric fuel pump. Please keep in mind that the gas is the from the same station in both tanks (I have tried different gas since), I drive her at least 3 days a week, nothing else has been changed to screw my fuel system up. I did replace the main tank sending unit a couple years back because my fuel gauge wasn't working properly (It didn't fix it BTW)
PROBLEM= My auxiliary tank giving me no issues at all. BUT while driving down the road/or sitting in driveway idling on my main tank, it will ERATICALY stop pumping gas. No pattern at all...some days I can drive it for 10 miles stop and start and have no issue. Some days I can't get out of the yard before I have to switch to auxiliary tank. Fuel pump still pumping, new fuel filters before and after fuel pump, replaced gas line from main tank to fuel selector switch because I thought the plastic line was kinked. Still doing it with gas cap off so not vapor locking (I even swapped gas caps to see if it would solve problem). The only thing left is the sending unit. So as soon as the weather breaks Im gonna driver her on the main tank until it stops then switch to aux tank and keep doing this trick until I burn my gas out of main tank.
FIRST QUESTION= It looks like I MAY be able to take out sending unit without droping tank, is this possible?
SECOND QUESTION= My theory is the sock on the end of the sending unit is sucking shut. I had this happen on other vehicles. What do you think?
Thanks for any help,
Professional Parts Changer
Mark
Mark
