Another half cab no more
Heat
I purchased this bronco from a another member of the fourm as a half cab. The bronco was extremely well setup just lacking the room needed for my family.
So removed half cab, bulkhead, fuel cell, roll cage, and other accessories. Had Dave Virga replace the rear floor and build the cage. I installed a new 23 gallon tank with GM pump, rear seat with 3 point seat belts, cut down the front bumper, added new Warn winch, and factory grill trim.
Still working on fine tuning the fitech. I replaced a fitech temp sensor with a AC delco and am now reading accurate temp. I am hoping it will start learning, as the old sensor never got above 160. Also turned off Decel cut out, so now it doesn't die coming off the freeway. Got a slight hesitation when you hammer the throttle but overall running well.
Sent from my SM-G935U using Tapatalk
KBUCK1
It looks nice. Better for sure. Looked good as a half cab also though
BRONCITIS74
Thats what is so cool about these old Broncos. You can easily modify them to suit your tastes.
