another lift question
MiamiMuffDiver
Miami
alrite guys help me out here, my truck has a block and add a leaf spring kit in the rear. im trying to figure out what height the kit was originally. im getting a measurement of 9 1/2" from the top of the diff to the bottom of the chassis. the rear block is 2 1/2" tall and the small extra leaf spring is like 5/8".
you think i have a 3 1/2 lift that has sagged down?
broncnaz
Well now it sounds like a 2.5in lift. that is if your talking about measuring from the top of the axle tube to the bottom of the frame. As to what it may have been well its hard to say as you cant know unless you had measurements of when it was installed and even then it will settle in a little. Do you have a drop pitman arm and a trac bar drop bracket? if so they are usually installed on lifts 3.5in and higher. but some people do install them on 2.5in lifts.
