Another 2.5" lift question
Zillacon
Hackin Away!
My rig is uncut. I would like to run 32x9.50x15 meats. Will they fit in an uncut rig with a 2.5" lift and what other brand other than swampers makes that size. TIA
jeffncs
Raleigh, NC
They shoudl fit, but you may experience some rubbing on the front fenders while turning.
I had 32x9.5's on stock rims with a 2.5 lift. It worked fine other than that slight rub.
Jeff
civilgee
Northport, Alabama
I have an uncut with 2 1/2" lift and 30" x 9.5R15 Mud Kings. I only get rubbing when I flex the rear. I would think that you would have to be very careful with the rear fenders. If it is a pure street rig, you might be ok.
76 bronco J
,,,,I believe the size & backspacing on the rims is a big factor along with the actual size of the tires because I have 15x7" later factory bronco rims with BF all terrains on a stock height supension and never have any rubbing with it twisted up as much as the little stocker supension will do.....
