Another One Bites The Dust!
crab
Well, here's my old '70 that I had 1000's of man hours and dollars into a total restoration. I sold it to a guy (Blake) in the LA area a couple years ago for $16K. After about a year he decided to move to Hawaii and sell the Bronco for $24.5K. After moving to Hawaii, Blake missed his bronco and tried to buy it back except the new owner had already dumped her on her side :'( He was out for a joy ride and claims part of the bulletproof steering sheared %) (Remember, it's grade 9 hardware). Fortunatly nobody was hurt except my old '70 (sporting the first Crab cage). But don't worry, my old '70 is safe at a vintage Ferarri restoration shop in LA undergoing yet another restoration to get her back on her feet. ;D
Here's some pics of the current condition...............
http://www.soluna.org/bronco/Desktop.html
BFPD630
Berthoud, Colorado
so whats the deal with the bulletproof steering? I have the same set up on mine- that is some serious hardware and that appeared to be a paved, straight road. Did you ever get to the bottom of what happened there?
crab
crab
I don't even know the guys name. The message is being relayed from Blake, the guy that baught it from me. He just said part of the steering sheared?? Looks like the bolt came out of the pitman arm. Still waiting for the details
crab
crab
I know for a fact that the suspention has been on and off over the past two years. I had a BC 5.5" lift and 35's with the TRO kit. Wouldn't fit in Blakes shop so he installed BC's 3.5" lift and 33's. My guess is the bolt simply didn't get tightened back up and pinned. I would buy another Bulletproof set up in a heart beat!
BFPD630
Berthoud, Colorado
yeah, I am real happy with mine. I'd bet that he skipped that last part of the installation where you have to drill the bolts and put a pin in them. I cannot imagine the force required to laterally shear a grade 9 bolt of that size, nevermind that there is no damage to the associated heim or draglink
crab
crab
I originally installed the Bulletproof system, and did drill the bolts and keyed them. But it has been taken off since I installed it. I'm more currious what the rebuild cost is going to be
crab
crab
Fortunatly it's not my dime. If the guy can afford to pay $24K for a bronco then have it restored at a vintage ferarri restorations shop, I'm sure he's not relying on an insurance claim ;D
BFPD630
Berthoud, Colorado
good point... but what would a Ferrari shop know about a Bronco anyway? If I had that kind of money I would quit my job and do it myself
TexZen
That's my rig. I purchased it from Blake in the Spring and drove it cross-country from Long Beach, CA back to Dallas, TX.
I was on my way in to work at 7:00 AM on a Sunday morning-- a special project I had to prepare for-- and took a little, paved country road.
I usually take a larger surface street in, one that's lined with telephone poles, houses and pedestrians, but it's a good thing I didn't that morning.
The max speed is posted at 45 MPH and I was doing slightly under that when I heard a VERY loud POP! and the steering went completely slack. The rig had, since I purchased it, a slight right-hand pull and that's the direction I went. Being a two-lane road, it didn't take long to be off of it and I was on the breaks. I ran through a low ditch and, once I hit the wet ground, locked the brakes. It didn't really matter as the tree and fence line is only about 5 feet away from that point.
The rig took on a tree at the right front side, catching the blow with the prerunner (which took it without a scratch). The scoop caused the rig to literally climb the tree and flip me over, rocking me onto the rollcage.
The cage propped me and teetered me back down on to the driver's side after coming -this- close to going belly up and I attribute it for my being able to literally walk away without a scratch.
I looked for the bolt but neither my wife nor I could find it-- no telling where it landed between the pistol's crack and the time I left the road.
I took it to Mastercraft Bodyworks in Ovilla ( http://www.mastercraftbodyworks.com/ ) after they came highly praised by everyone I talked to. The first car I bumped into when checking them out was a $300k Alfa Romeo. I figured the rig would be safe there, especially after learning it would be their 9th Bronco.
They took their time with it-- and, after they asked me the most dangerous question ever ("So, since we'll have it apart, is there anything else you'd like to have done to it?"), I had a few nips and tucks completed (weld and sand the bolt holes from the tire rack on the tail and repaint knocking out the Bronco lettering in white (it was painted over Hugger Orange previously), and repair the hood where it had weak spots from rust).
They did a fantastic job and it's back in 'show' shape. When the weather turns too cold to drive it, here, I'm taking it back in for killswitch and A/C installation (custom placement and grill-vent work).
I'll spare you the gory details as to what it all cost me, but I've already had three offers to buy it since I've had it back (not counting Blake's).
supermottl
Indian Harbour Bch,
I'm glad your OK. Nice to hear good things about the pre-runner bunpers, as I have 1 too..
I still think something fishy went on with the pitman arm bolt.... I wish there was more info...
crab
crab
I guess this just shows why these bolt ons are not DOT approved. We should all take this as a lesson and crawl under our bronco's more often to check for loose bolts and drivetrain componets. Most people have had simular things happen with PS boxes braking off the frame and track bar brackets.
Landshark
California
Hi Crab,
That's why in those types of requirements I would run a lower grade bolt. Since the higher grade are so strong, they tend to break instead of stretch, so if you ran a lower grade it would most likely stretch, instead of snapping off.
TexZen
I took the pics down early this AM when, upon waking up at 4:00 AM and seeing a few hundred hits (multiplied by, oh, 20 100k photos or so), I freaked over the fact that a site I had created for one person (Blake, who had asked for the pics) had gone "public" in the very widest sense of the word.
The link (in the original thread-starter) is back up-- at least until I bump up against my bandwidth quota (so get 'em while they're hot).
Any photo that doesn't have the Bronco on its side, leaking oil or on the back of a tow truck was taken after I got it back from Mastercraft.
crab
crab
I guess the owner removed the link, but he hasn't returned my emails. I guess he doesn't want to talk about it? I just happened to save the pics, so here are a couple. Has anyone heard of a 3/4" grade 9 bolt snapping?
TexZen
Yeah. I have.
And I hadn't had a chance answer your email (singular) because I've only just now returned home.
NicksTrix
link works now.
the bolt shouldn't have sheared. there is no indication of enough force to shear it, as the heim is still intact. the monoball & casing are still round. i'd have to say the bolt got loose and fell out. i've seen aircraft grade heims that have had the casing split and peeled on the impact, yet the gr 8 bolt was still intact.
looking at the pictures, i noticed that the heim on the knuckle is double nutted using 2 castle nuts. why not a good locking nut or drill the bolt to use a pin in the castle nut?
shame it got flopped. i remember the ad on ebay for the truck a while back. it's a nice ride.
