Another one bites the dust.. :( alum...
Madgyver
Bronco Madman
What do you guys do with your radiators? I have had a RD radiator for over ten years and no leaks and nearly that long in another vintage vehicle with no problems. You guys are scaring me.
my RD radiator lasted 13 months. 1 month after warranty expired. Talked to the man himself and he said "No"
Yeller
Rogers County Oklahoma
Nope, never had an issue with electrolysis. Never use anything other than 50/50 premix coolant. I used to have crazy hard water that would corrode anything, so I just quit adding water to concentrate, never had an issue.
ba123
CA
Are you guys using sacrificial anodes and grounding the radiator to the frame to prevent electrolysis?
I have an anode just in case but yeah, def don't use tap water unless you're stuck at the side of the road and that's all you can get.
+1 on premixed.
nvrstuk
nvrstuk
PNW
I just buy some distilled water for initial mixing and then add later after I replace another radiator! lol
I use it for all my farm equip & everything else with a radiator
I also use an anode. Being a salt water boat guy it's what I do...
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
I have used a 50/50 mix high quality antifreeze, sacrificial anode, and ground strap on my aluminum radiators. After 15 years I am still good on my RD aluminum radiator. I will note that I had to replace the sacrificial anode as it did indeed sacrifice itself after 12 years.
gnsteam
Lincoln NE
Mars, So what are you using for the anode and where do you install it?
