Another Pitman Arm Question
mrdrnac
My Bronco was converted with a saginaw power steering box out of a early 1970's Chev Van. Is the output shaft sizing and splines the same as used on the Ford and Bronco boxes? It currently has a drop pitman arm on it from another GM vehicle (Unknown) but the drag link end had to be modified with a different end on it to fit the taper size. Would rather go back to the stock style of Bronco drag link if it will fit.
Surprised nobody chimed in on this one yet mrdnac. Unfortunately, even after all these years of messing with them, I don't really know with 100% certainty either!
I know all the rigs used different arms, but don't know that a Ford arm won't even slip on to a GM box. Even the original '77 EB box was a Saginaw box. Just a different design.
What year is your EB and what steering linkage is on it now? It might be simpler to keep your arm and modify the hole to accept the tapered rod end of your choice, or upgrade to a beefier steering setup that would fit the (I'm guessing?) larger hole?
Got any pics you can post up?
Be very interested to see what you've got. Was the frame notched to fit the box, or was it bolted on with brackets? Or straight to the outside of the frame?
You don't happen to have a Jade Green '70 by any chance? Knew a guy around here that had a similar setup years ago.
mrdrnac
mrdrnac
Thanks Paul for answering my posted question. Wild Horses is my preferred vendor for Bronco parts. In fact, I think you helped me on the phone a few weeks ago designing my new Wild Horses custom steering shaft!
My Bronco is a 1966 U13, that I did some serious modifying on in the late 1970's before there were many parts available for the early Bronco. The current sterering linkage is stock 66 Bronco with a different sized upper ball joint grafted on it. The saginaw gear box used was from a Chevy G10 Van, 71 to 76 models. It was mounted on the outside of the frame and works fine, see the links to the Photos showing how the box was mounted, bolted through the frame and onto a 3/8" thick steel reinforcement plate with 4 bolts, the holes in the box are threaded so the bolt heads are on the inside of the frame. The input shaft on it was 13/16"-36 spline so the regular Bronco Power Steering u joint fit that end OK (Flaming River #FR1719).
But the current Pitman arm (Semi-Drop style, origin unknown) required a different size tapered stud (Small diameter .516"; large diameter .626") than what the Bronco had used originally so the drag link end was modifed on the pitman arm end. Not sure if the current tapered hole is larger or smaller than the stock Bronco one. Now I'm thinking I would be better off to go with the stock Bronco type of drag link, if possible, and switch out the pitman arm; if the drop Bronco pitman arm will fit the output shaft on this box. The reason for this is the current drop is 3" and I believe a 4" drop pitman arm would help the steering geometry.
So that now is my real question, Will the drop Bronco pitman arm fit on this saginaw steering box output shaft? Or perhaps your idea is better, find a Chevy Drop pitman arm of 4" and modify the tapered end to fit the Bronco linkage.Thanks for your help!
http://s288.photobucket.com/user/Mrdrnac/media/photo1.jpg.html
http://s288.photobucket.com/user/Mrdrnac/media/photo2.jpg.html
http://s288.photobucket.com/user/Mrdrnac/media/photo3.jpg.html
Mrdrnac
