greasypigeon
Ok for the past few days I have been fighting my motor. first the starter. Fix, then after I fixed it I drove to work the next day and it idle great. As I level work, for some reason it idles at 2000rpm. So I take apart the carb replaced the needles cause one was falling apart and the secondary float was stuck. Then it starts to flood out then vent tube. Swapped in another set of needles. Fired right up idle fin, for about 10 minutes then same problem occurs it idles at 2000rpm. But the day I replaced the starter and the day before I had a high idle I was the engine really good. Would a bad coil, or ign do this?
