As I plan for a transmission replacement in my '70, I'm going to get in there and replace the rear main seal.
I feel bad for asking this, but am really not finding the answer. Is there a repair sleeve (w install tool) available for the rear seal? If so, can someone point me towards a specific part number please
I'm inclined to stick with the stock "rope" seal, unless the new "rubber" two piece seal is that much better. If so - pointers towards the install process (which seems to be: grind down or otherwise remove the pin in the rear cap, sealing its hole with a dab of sealant) and the best brand / part # to use would be appreciated.
Thank you,
Jerry
Thank you,
Jerry
