Raskew
I completed my Chevy disc conversion this evening and all went well until I installed the passenger side caliper. The caliper barely fit behind the rotor and it rubs too hard, not alllowing the Rotor to move without some major effort. If I push the piston in, it will free up the rotor a little. The Rotor rotates easily without the caliper installed.
The master cylinder is new from a 77 Bronco.
What could cause this rubbing? I'm wondering as I type this if the backing plates could be two different thicknesses. Could that cause a problem. I bought the backing plates from a junkyard and they look the same.
Any suggestions would be appreciated.
Rick
Rick
