- Nov 1, 2003
- 770
Yes, another one. I've read about it for years, taken in the knowledge, but never really experienced it and thinking that some feedback based on my circumstances might be helpful.
I've got a 2100 carb and have had the Bronco for about 18 years. Never runs hot, meaning it's typically at 180 degrees in most situations...even in 100 degree parade (5 mph) driving several miles. Maybe gets to 190. Since last tuned, it was at about 3200 altitude.
A few days ago went up a trail outside Albuquerque. About 5500 altitude. Decent grade, going slow, a bit rocky but nothing terribly challenging. Only went a couple miles in, about 90 degrees out, and coming back flat + downward grade it just wanted to stall out a lot and had to restart many times. Temp gauge 200-205. Still not bad, well within operating range.
Again, doesn't seem to be an overheated engine. Have I ever really been on a trail in this rig since I've owned it? No. Deep snow (10 inches), across town in TX panhandle in FWD yes, but flat and performed extraordinary. Driving up a mountain in WA to a ski at high altitude? Yes. But warm weather in mountainous terrain no.
So I let it cool off a bit and things got better, but just enough to get me out. And in city driving after leaving, when things really cooled down, was just fine. And driving since has not been a problem, so I don't believe there is a chronic issue with the carb or fuel delivery.
I'm thinking it's not engine temp but rather a fuel issue. Either carb isn't tuned properly for the altitude or there's some vapor lock going on.
So...let's say I check for an in-line filter and get rid of it (beyond the one that's at the carb.) Then I check to make sure that no lines are near exhaust. Assuming the mechanical pump is functioning properly. Assuming that the tank and fuel are clean (tank was replaced a few years ago.) Maybe replace the fuel filter at the carb as a precaution.
Not trying to throw money at problems, but looking for improvements when I go out again, thoughts on the following in addition to the few things listed above:
1. Re-time the, well, timing? Easy enough and will try.
2. Re-tune the carb? Easy enough also.
3. Get an electric fuel pump? A decision.
4. Some insulation on the lines where there might be heat issues. OK.
5. Get a non-import, Carter mechanical fuel pump. Worth a try? Hasn't been changed since I've owned it.
Any other approaches are welcome. I've got time, lol. I know it could be a myriad of issues, but again other than the obvious carb failure/issues that demand a rebuild (in my case about every 7 years, but it otherwise works fine right now.)
Thanks.
Thanks.
