behemoth
- Jul 2, 2003
- 1,736
On a previous bronco the coil wire was removed and replaced with vac line, the hood prop rod was also removed. This was with the stock hood, and the 5.5 suspension lift. I figure the little suckers would get really tired of holding that hood up while trying to use the remote start switch and the coil wire.
My only concern then was a personal injury suit when they drop the hood on thier hand or buddy.
Turning the tank selector to the middle, so it will not run long, wiring the horn to the dash tank selector so that when it is flipped to aux or main the horn sounds.
The grant wheel lock as well as the brake pedal lock work well. locking the brake pedal to the clutch pedal also works.
The colum shift auto and the shifters on the floor seem to slow down everyone else that gets in the truck.
