I'm using a 76 D44 Disc Front axle rebuilt to stock specs with rebuilt calipers, new rotors and pads, new ball joints etc. I was considering using stock rear drum brakes, but when I was checking the brakes out, I see that the wheel must have came off at one time and the backing plate ground the poor old thing to a stop. It was working fine but its missing a huge chunk off the bottom of the backing plate, besides needing new shoes and wheel cylinders. Then I found a cheap Super Duty hydroboost. That's when I got to thinking about upgrading the rears. I like to keep my Ford pure Ford if possible. If GM made all around better stuff, I would probably would consider putting it on there, but it seems like it all has pros and cons and the GM stuff isn't cheap so why not make it all Ford. Ford Racing has the Explorer setups for the Torino flange brand new for $350 so that had been something to think about. However, I don't think the Torino flange came around until the 70's sometime. I do think i read somewhere the axle offset is right for the small bearing. Back to the crown vic, I thought the emergency brake was seperate from the caliper. The one I played with had an internal mini drum brake built into the rotor. I had an 03 Marauder that was that way, but I messed with an 01 I believe that was the same way. I could see if that setup is the same that it would cause some problems routing the brake cable.
