Anyone have a Millermatic 211
Looks like I will have to look into getting one, especially with the 200 rebate and free spool gun! I was originally looking at the 212 but I think the 211 will do everything I need.
phyler
Denver area
Not sure if you have looked at cyberweld but they have the best price on the 211 right now that I could find.
EricLar80
I bought mine from ebay from whoever had the lowest price and free shipping. It ended up being less than cyberweld, and Miller accepted the receipt for the rebate.
Eric
I have a slightly smaller 180. It has done everything steel. I have only hit the thermal overload a couple of times, and I was running it stupid hard to so that (welding quarter inch plate to a scraper blade). The compact size is great for home use.
Steve83
I love my Miller 211... It makes a novice welder like me have beautiful strong welds!
x2 !!! ;D
Those who own an auto set miller do you like/use this feature, or do you run primarily in manual mode?
Full-auto. I don't know enough to read my own welds & adjust it, and I already get great welds in auto.
The rebate and spool gun are the reason I think I will pull the trigger on it.
Before you do that, check eBay. I got mine with the SpoolMate for ~$300 less than Miller or anyone else was offering.
Everyone's first project: a cart.
But I quickly got sick of giving it the ol' reacharound, so I moved the power switch to the front panel.
And finding a wrench to change spools got old really fast.
I still don't have a good helmet, but the cheapo I've got does OK for the little welding I do. I really like Hobart's 770440 gloves, though.
http://www.amazon.com/dp/B000SST7IU/
krause
I have the 211 and love it. Best price I found was an eBay seller even after millers rebates
76Bronco302
Sherman, Tx
Ebay is where I got mine. Even came with a cart. But your first project should be building a new cart for your future plasma cutter
Whoaa
I did some really light welding w/ my Miller 211, on the auto seting when rebuilding my top...
And here are some raduis arm brackets I welded to the frame, auto setting- Miller 211..
Used my little Miller 211 for welding this mount on the rear diff housing
New spring perchs. This welder is easy to use! It makes a decent welder, good...and a good welder excellent...so easy to use for light or heavy material
