trailpsycho
- Dec 11, 2003
- 4,856
My windshield hinge area was clean and all when I did the tear down. Media blasting had it all nice and clean along the seam above and below the hinge as well...but the new paint appears to be cracking along the bottom edge of the hinge. Bodyshop is willing to repaint the area, but fingure I should go ahead and replace the hinge and minimize future problems since the truck is mostly bulletproof.
My thinking is drilling/spot-weld cutting the original hinge out. Its not a problem to weld the new SS hinge in, but I am thinking that the new body panel adhesives (BPA) would be a great product for this task. Maybe add 4 SS rivets (per surface) as well to help with the clamping force during curing. The BPAs are supposed to provide amazing cure strength. It would eliminate the need to have have a seal or use seam sealer at the two hinge mating surfaces (windshield frame and cowl) since it acts as a total barrier to moisture getting in between the hinge and cowl (or WS frame). The stock seal will still fit and the hinge will function and close. The hinge can be left in natural SS finish this way as well, if preferred...for a little bling. What do you guys think?
