Anyone using these?
bigjhoov
nobody
Anyone here using the conversion bearing that allow big bearing axles to be used in small bearing housing? I'm being discouraged not to use them because they are wider or something and don't allow the brakes to line up or something like that. No one knows for sure which it is. Just by measuring them they are approx. 1/4" wider that original. Just curious if anyone has had a problem with them.
I would have just bought some alloy 28 splines and been happy but I think I blew the Detroit the same time I popped an axle. My other option is to find a 74-75 housing so I can run big bearings with my 10" brakes, or just get a big bearing housing and 11" brakes.
I don't want to get the 31 spline small bearing axles because I think that severely limits me as far as spares. I think that is getting too rare to be able to find replacements in the future.
bigjhoov
bigjhoov
nobody
Thanks Jon, I think I'm just going to get a big bearing housing and go from there.
BlackHorse
That 1/4" may or may not be a big deal you will lose 1/4" of spline engagement in the diff. That's not good but could you run with it? Yes. On the brake drum side if you have 1/4" of space on the inside of the drum you might be OK there too. But I would not do this unless that was all the buget allowed.
28 spline alloys are still 28 spline IMO 28 spline=weak axle. Bad choice for any wheeling rig. You would still need new backing plates to run you 10" drums. Or at the least you would need to machine out the center hole and retaining bolt holes to match the 74/75.
The thing to remember about the 31 spline with the small conversion bearing is that the bearing can be removed and a set of LB tapered bearings can be installed later if you ghange to a BB housing. With the 2 1/2" offset there are a bunch of disc conversions also.
Good luck!
