I'm getting ready slap an AOD in the EB. The AOD I have came with a J shift transfer case bolted to it. I have a T shift transfer case that came out of my EB and that I was thinking of running. I pulled the J shift case off the AOD last night, and it looks like I need to change the input shaft into the transfer case over.
The T shift I have was behind a C4 with a factory Bronco adapter. As can be seen in the pics, the input shaft length is about 1.5" longer on the T shift case vs. the J shift case. I didn't assemble this AOD combo, so I'm not sure what is all included in the conversion. I looked on Advance Adapters site and see there is what appears to be a transfer case input shaft in the pic??? Does this AA conversion come with a unique input?
Since I was thinking of running my existing T shift behind the new AOD, how difficult is it to change over the input shafts from the J case to the T case? Do I also need to switch over the aluminum bearing holder that is on the transfer case? I looked for instructions downloads on the AA website, but I don't think they have any listed online.
Also, how many bolts should there be attaching the AA adapter to the AOD case?
Blue case is the J shift.
