Well I'm still fighting issues with my aod after doing the 4r70w gear swap. First was a bad governor keeping it stuck in first, now I'm getting weak up shifts and line pressure loss for 2-3 shift. Light throttle is a somewhat firm upshift from 1-2, soft 2-3 and soft 3-4. If I do heavy throttle all upshifts feel soft. TV cable is currently 60 psi. I'm thinking I might have torn a seal on the direct drum piston. I have also swapped out valve bodies to eliminate that with no change. I'll probably be pulling it tonight to tear back into it.
Line pressure readings stopped
Park 120
Reverse 190
Drive 125
Driving light throttle
1-2 150
2-3 100
3-4 150
Driving heavy throttle
1-2 200
2-3 100
3-4 ran out of road
Park 120
Reverse 190
Drive 125
1-2 150
2-3 100
3-4 150
1-2 200
2-3 100
3-4 ran out of road
