AOD T.V. Pressure
377
The Bluegrass State
I thought I was about ready to hit the road with my rig after two years of building it but, that was until yesterday. I went to set my t.v cable using the Lokar t.v. cable and shifter arm. Installation of Lokar products went well until I began the procedure of setting the t.v cable line pressure.
I first attached a pressure gauge to the appropriate test port on the transmission. My second step I set the cable stop so it had no slack or pressure on it. I then started my rig up let it reach normal idle and a trans temp of around 150 degrees. I went to place the truck in neutral so I could use the lokar gauge on my t.v. cable to insure the cable set correctly. While in park the pressure gauge read about 50lbs. From what I have found while in park the gauge should read from 0 to 5 lbs. I went ahead and placed the truck in neutral and slid the Lokar gauge onto the t.v cable, pressure gauge read from 43 to 50lbs, not the 30 to 35 lbs that ir should have. The variation resulted from adjusting the ferrules on the t.v cable housing. At that time I put the truck back in park which resulted in the gears slightly grinding going back into park. That also made me think what the pressure gauge showed, way to much line pressure.
After doing some research I found a number of people saying they installed a carberator return spring on the back side of the t.v. cable to insure the arm was pulled back solidly into it's correct position. So I installed a carb return spring and went through the pressure testing I got the same pressures again along with the same grinding going back into park.
Can anyone tell me what is going on? The transmission was purchased from Monster Transmission about two years ago. It was recently installed and prior to installation was stored in a dry/controlled tempature environment. The t.v cable and arm are Lokar and were provided by Monster with the transmission. The shifter I am using is a Winters shifter with a Lokar shift arm that seems to work and shift through the gears correctly. My pressure gauge was purchased from Harbor Freight and is brand new. Not sure if it makes any difference but I am using Royal Purple Synthetic Fluid in the trans.
If anyone has any experience or advice they can give me I would really appreciate it. I do plan on calling Monster but, if there is something else I can do I would like to try it. Thanks in advance, you guys have always been I great help in the past.
377
E arm
needabronco
Prescott/Farmington
Too much pressure will result in firm, higher RPM shifts. Too little pressure will smoke your clutches. I'd say your transfer case is in neutral or your shift linkage isn't shifting gears correctly? Is the something backwards or is something in the valve body not hooked up? I seem to remember a shift ball on the linkage and the valve body that needs to be placed correctly in order to shift?
377
E arm
Transfer case in neutral or driveshafts missing. Output shaft was spinning, thus changes to governor pressures and most any other pressure in the transmission. Error in testing method results in error in test results.
Oh, the grinding gears were not gears. It was the park pawl bouncing around trying to lock a spinning output shaft.
OX1
So you are getting 40-50 @ idle and with the cable pulled out somewhat?
Tried disconnecting cable completely so it reatracts all the way and read the pressure?
377
The Bluegrass State
Broncobowsher,
I wasn't sure of the relevance on the transfer case position. It makes perfect sense though you raise a 2wd vehicle up while in neutral and your tires will still spin a little. So the output shaft is still spinning a little and causing the higher pressure. Is the output shaft still spinning in park though? I did back the barrel lock off the cable and was still getting high pressure. But like Broncobowsher said an error in testing is going result in an error in results. My buddy and I had just installed new detent springs and balls on the transfer case prior to working on the t.v. line. I am hoping that thing is in neutral! You guys are great! I'd have been up the creek a long time ago if it weren't for you guys. Thanks again, now to get off work and check my transfer case!
377
377
The Bluegrass State
Back to square one, the transfer case was in high.Went through the set up again and got 50lb pressures again in park and neutral. I also backed the barrel lock off so it wasn't touching the carb linkage. Still 50lb in park. I called the good folks at Monster Transmission that was about as smart as pissing into the wind. Didn't get to speak to a tech but, the receptionist spoke to one and he said the cable had to much tension on it. Odd thing is since I followed the instructions it had no tension on it. Since I was already pissed instead of blowing up I told them yea I'll try that. I figured I'd sleep on it and hopefully cool down then call them again tomorrow. If anyone has any further suggestions or insights on this thing I'd really appreciate it. Thanks again.
377
BRONCROB
WISNER LA.
Make sure your d-shaft is connected or you will still get the same thing as tcase being in neutral,didn't see where you said it was installed??
PaveBronco
Hate to beat a dead horse, but can you verify the T case in actually engaged, either jack the back up and try to turn the driveshaft, or when you go in to drive does the truck Jump or move like it wants to go.
377
The Bluegrass State
The transfer case is in 2 high , I have backed my rig in and out of the garage a couple of times. I also talked to a guy who said the constant 50lb pressure could be a sticking pressure regulator valve. He had seen the exact same thing with another AOD only differnce in the other case was there was 80lbs of constant pressure. He said with the AOD no pressure is what fries them, the higher pressure wouldn't kill one but it might shift hard. He recommended setting the tv cable with the Lokar gauge and taking it for a short drive. He also said I might want to leave the pressure gauge hooked up to see if the pressure changes while driving. My trans is set up with a temp gauge so I can be sure it isn't getting hot. I think I am going to give the test drive a try before I yank out the trans and send it back to Monster.
377
PaveBronco
I'd be interested to find out how it drives and what the pressures are. I wonder if that's the way Monster builds them? or the trans just needs to be exercised to break it in.
01Dudley
Knoxville
Have you called Lokar? They might know something about higher pressure on a performance build AOD. (865)824-9767
377
The Bluegrass State
I received a call from Monster today after I contacted them and told them what I was told about the test drive. The tech said to give a test drive because it very well could loosen things up. He said the same thing about as long as you have pressure you're fine, no pressure and you have a problem. I hope to put my rig on the road for a test drive in the very near future. I'll post the results.
377
Pa PITT
Stephenville TEXAS
Well I didn't read all those post . It's late but My Running Buddy just installed his 3rd AOD in his Bronco . & the 1st time he tried the after market cable you mentioned .. But it was never correct & His 1st burned up in 23,000 mile like everyone on here said it'd do. So with this last FRESH AOD .. His rebuilder told him too hustle up a stock cable from the wrecking Yard & they would use that. . He Did & It adjusted the 1st time . But the Local Ford house did the adjustments so I have no clue as to what the amounts were.
