astro van M/C brake lines ? HELP
DEEPWOODS
Is the brake line fitting hole that is at the rear of the astro van M/C the one closest to firewall for the front or the rear brakes? Thanks for the help, Keith
rjlougee
Generally, if you're running a disk/drum setup you want to pressurize the drum brakes first, so the rear brake line goes in the fitting closest to the firewall.
Joe
Scoop
Bronco Old Fart
Cuchara, CO
Big reservoir goes to front brakes, small to rear. You want the fronts to lock up first.
