Our Wild Horses “direct fit“ column would likely be the closest to stock you’re going to find.
You’re still gonna have to heavily think through, and even tweak the wiring a little bit though.
They are based on 74 and later models, so some of the colors might vary.
But that’s not neither Painless or the column’s fault, necessarily, as 73 had multiple wire color changes during the model year. So you may already have dealt with that, having connected the Painless harness to your original column to begin with.
It uses a Bronco turn signal switch for a 74 or later later model, so you will need a relay in the horn section of your harness. Which the Painless harness may already have supplied, and you may already be dealing with.
The real mind games are connecting the hazard switch wiring. The new one would now be on the column instead of the dash.
Or, alternately, you could retain the dash switch and leave the wires for the column switch inactive. Some remain necessary, because they are part of the brake and turn signal section. Others might not.
I don’t really know which is the better or more viable solution.
But what you end up with is a column that will accept the stock steering wheel, A known turn signal switch for 74/75 or 76/77 Bronco, and factory style connectors.
Just not necessarily the one you have on your 73.
But with the Painless replacement harness, you may no longer have your original column connector to deal with anyway.
The standard generic columns are usually much less expensive, but then you just have to remember to get steering wheel wheels and adapters for GM vehicles and turn signal switches from GM vehicles.
Not a huge deal, and I don’t know anybody yet or don’t remember hearing about it here, who have had issues with their generic turn signal switches.
But the main issue I see from your post, is potentially using a stock steering wheel. So I’m pretty sure that leaves you with either a stock column, or one of our Direct Fit replacement tilt columns.
Still doesn’t hurt to call in to get second or third opinions. Hopefully you’ll get that here in your thread as well.
There might be other options that I’m not thinking of. Such as junkyard hopping and crawling, looking for a different model from a Ford truck.
