Dans72
- Aug 13, 2021
- 28
So I'm currently in the mode of acquiring parts for my 1972 Bronco and trying to plan parts for the build. I've already got an Explorer 5.0 that I'll be running with a Holley Sniper or maybe FiTech EFI. The transmission is where I'm conflicted. Really, really want to go with a 6R80 so that I get the low first gear to go along with two overdrives for fuel economy as I want to build a jack-of-all-trades vehicle with this build. I won't really use it as a daily driver, nor will I take it off road much, but I would like it to be able to reasonably be competent at both tasks.
With the 6R80, I've came across an adapter plate that adapts a SBF to the transmission. But the part that I don't like is that you have to cut a portion of the bellhousing away so that you can use a Windsor starter. I really don't like the idea of doing that. The controller for the 6R is considerably higher than the 4R70W controller.
I've began to resign myself to using a 4R70W instead. If I used one originally designed to fit a 5.0 I can eliminate the need for cutting the bellhousing, and using the adapter plate. But I keep telling myself that driving where I live, I'll really miss the extra overdrive gear. I had a 2006 F-150 with the 4R75E and I always felt like it needed another gear between 3rd and 4th.
If anybody on here has put a 6R80 behind a 302 or 351, I'd really love to hear your input. Was it worth it?
Even if you've put a 6R behind a Coyote I'd like some input. What kind of body lift is necessary to clear the transmission?
