Autolite 2 barrel issue
tater_51
Went to start my 73 Bronco today and had gas pouring out of the top of the carb. It's an autolite 2 barrel that I've ran for years without issues. I pulled the original 302 years ago and put in a 99 5.0. I chose to keep the original intake and carb. I removed the top, swapped out the float and needle valve hoping that was the issue. Once started it looks like "Old Faithful" with fuel just shooting past the needle valve. This combination has ran like a top for years. I'm at a loss on where to look for the issue, any help would be GREATLY appreciated. Thanks
T
tater_51
I tried to download a photo with no luck. I believe its just a stock pump, nothing fancy. Not sure if it's a 302 pump or the 5.0, either it had worked great for years. Can a bad pump increase the flow?
ksagis
Aspiring Bronco Guru
Austin
Maybe dirt/FOD in needle seat area but seems like with the flow you described the flow would have flushed it out.
Can you inspect the seat area?
T
tater_51
You have to be a forum contributor to post photos. So just a block-mounted mechanical pump? Not electric?
Yes, just a block mounted pump. I swapped out the float and needle valve but not the seat. I'll try that tomorrow. I don't see anything visually blocking the seat. I have a box of NOS parts from carb rebuilds back in the day. I've been a forum member since 2014, just an old illiterate on posting photos.
73azbronco
Can you put a mechanical on a 5.0 block?? I suppose depending years, but, last years were mustang with carbs right? 85?
T
tater_51
The 302 came out of a 99 Mountaineer. I removed the EFI to keep the original intake, etc. The pump is mechanical on the block, don't recall if I had to add a fuel pump eccentric, it's been a lot of years ago. Whatever, it has worked flawlessly for a lot of years.
T
tater_51
Back and running. Not sure exactly what the issue was but after cleaning the needle valve and seat with carb cleaner and swapping back to my original float it's running nice and smooth again. Glad I took another stab at it before replacing the pump.
Just be on the lookout. Very likely it’ll happen again at some point.
Could be debris, could be modern fuels wreaking havoc on internal parts, could be crappy new parts. I’m glad you have a stash of old original parts.
Even a needle-and-seat are probably not as good new as they once were.
The old standby “quick fix“ was to tap the carburetor near the float with the handle of a heavy screwdriver.
Metal tools work even better, but mar the finish on the carburetor. Eventually, the plastic handles will leave marks as well, but not as quickly.
At one point in its life, my 71 was doing this, or a variation of it, every other day. Needless to say it was very frustrating!
And the primary driver towards fuel injection.
One day, it would puke fuel out the float bowl, another time it would starve for fuel.
In the cases when it was starving, you could literally hear the whoosh of the inrush of pressurized backed-up gas in to the bowl as the needle released, after tapping the carburetor.
T
tater_51
Knock on wood, you were right!! I replaced the needle and seat and it started and ran like a clock. Went out today and same issue, puking fuel and would not idle. I'm at a loss, I have parts to replace not where sure to look. We have a Bronco take over in a week, I'd sure like to get this issue resolved. Any ideas? Thanks for the help
T
tater_51
Dam thing, just popped the top, played around with the float and needle valve and it's running fine again. I'll see what tomorrow brings on start up.
You’ll have to keep at it.
Smack the carburetor around a bit and see if it fixes it.
But if you haven’t already, you’ll probably need to check the fuel pressure. Buy or rent a gauge and connect it. The only two things I can think of that would cause this are, too much fuel pressure, or an ineffective needle and seat.
When you had it apart, it didn’t feel like there was any gas in the float I suppose? A failing float will always stay too low and keep the needle open.
In the old days, back when fuel pumps were good quality and almost always worked properly, the stuck needle and seat was the most common issue.
Nowadays, however, faulty fuel pumps, even those that have been working for a while, seem to be more often the cause than not.
We’re discussing it on many forums, where a brand new fuel pump could put out anything from 10 to 12 Psi, to nothing at all.
And then the ones that do work, fail within a few weeks.
Remember though, with modern fuels not a single mechanical fuel pump that is a standard replacement, plays nice with the new fuels.
You might drive it one time, then park it for a month, and your fuel pump is dead.
There are probably expensive aftermarket fuel pumps that are designed to work. But your standard over-the-counter style are usually not among them.
