- Sep 20, 2018
- 324
Getting ready to install some gauges just want to confirm I understand this before I do it.
Photos attached:
The back of the gauge has (03) spades- "S","I", "GRND". Do I have these labled correct? Is the "I" go to ignition/accessory so the gauge turns on when you turn the truck on?
The plug on the transmission, is this the correct location to put the adapters supplied?
Does the wire go from the "S" spade to the adapter on the transmission for the reading? The only parts supplied with the gauge was a "short " wire (no way it would reach from the cab to transmission of an vehicle unless it was a hotwheel) and the adapter for the transmission.
The wires for the lightbulb one is ground and the other connects to light switch?
Am I close to pretending like I know what I'm doing?
Thank you in advance for your time/help,
Sonny
Photos attached:
Sonny
