Desert Thrasher
- Joined
- Jul 14, 2001
- Messages
- 2,353
Ok so I swapped in a 1990 Bronco 5.8, converted it to mustang EFI with RJM harness.
I have autometer electric guages, I originally tried using the stock sending units from the 5.8. Didnt work, found out I need the autometer sending units. Bought new ones and the water temp works fine now, but the Oil Pressure doesnt work at all. I even tried another autometer sending unit incase the new one was bad. Still doesnt work. Guage doesnt move at all.
I have the extension unit and the sender threaded in with No teflon tape, so it should be grounded fine. I did have to extend the wire from the RJM harness. Would the guage read anything if the wire I extended was not connected good enough? Or would it read intermittently?
Could it be the RJM Harness? Not meant for a guage, only idiot light?
What do you all think? Thanks.
