tbrend
Hello,
I purchased a set of Hella 55 watt aux lamps for the Bronco.
It came with a relay, switch and instructions.
The instructions say to run a wire from the high headlight wire before the bulb.
I have upgraded the original headlights to a H4 with halogen lights. I also used a "plug and play" lighting relay.
Where can I get the high wires for the 3 prong switch? From the original harness or from the relay? Any idea on how to find out which wire is which?
Also, does that mean they will only operate when the high beam is on? What if I want them on with the low beam?
