Axle Refurbish
NorCalBronco
Hello all,
I have a 72 Bronco that I have owned for around 16 years or so. Its been built up, beat up, rolled, re-built, etc and in all that time I have not touched the axles in any way. I recently bought a house and actually have a garage to work on the thing again and want to start going through stuff as its in need of about everything it seems.
It has a drum brake 44 front and a big bearing 9 in the rear. 4.11 gears. The rear has a worn out limited slip. They look like just about everything leaks.
I have some disc brake knuckles from a 78/79 bronco that I would like to get installed and maybe a basic locker like a trac -lock?
What parts should I replace/refurb? I'm kind of looking for a noobie check list of stuff I would need.
And here is a pic of the Bronco andmy wife being a dork just for the hell of it :
Thanks!
Well congrats on the house first of all. For sure.
As far as the stuff-to-fix goes, rear axle bearings are always near the top of my list.
Big bearings are good for between 100k and 140k miles, and anything over that is just waiting for disaster. And the harder it was rode and wetter it was put away, the sooner they go out. Mine were toast at approx. 90k miles. So you see why I'm always on about the rear bearings.
And you use yours like it was intended, so...
Darn good excuse to inspect and adjust the rear brakes, and even more so to change out the lube and put in a new housing gasket and end seals.
Front wheel bearings get some love too. Easy to pull and re-pack, change seals and clean and lube the lockouts. If regularly maintained, the front bearings can last the life of the vehicle. More often than not they get ignored a little longer and may need to be replaced. Anywhere from 50k to 100k if not taken care of diligently.
But everything will thank you for checking and adjusting them now even if it's been awhile.
Trac Lock is not a locker. It's just another limited-slip with "lock" in the name to confuse the public. If you have a stock one it's easy and very inexpensive to replace the clutches and off you go. Depends on what you want to end up with and how much money you have to play with, but a Truetrac(sp?) would be my first choice if I needed to replace one. I have a perfectly good 4-pinion Ford Racing Track lock(SP?) in mine and intend to leave it until it needs replacing. Good enough for me and I've already upgraded to 31 spline axles so am good to go for now. If I do buy another one, it'll be a Truetrac.
It's also a limited-slip, but with no clutches to wear out.
The full-size Ford disc swap is a great setup. Also have that on mine.
It'll all bolt right on to your '72's front end, but you will need to fiddle with the steering linkage/rod ends because the larger knuckles also have larger tapered holes in their steering arms.
Easy to do nowadays though, with tapered sleeves like the #2382 down this page: http://www.wildhorses4x4.com/category/Custom_tie_rods
Or if you need to upgrade or replace your steering linkage for whatever reason anyway, you can get the fully adjustable linkage with the larger ends already.
Many more options than way back when.
Should be enough to keep you busy for a short time. Plenty more to do to a 45 year old truck though.;)
NorCalBronco
NorCalBronco
Thanks for the clarification on the track lock. It did seem cheap :) A good limited slip in the rear sounds like it could be a better choice than a full on locker so maybe just replace the clutches on the stock one?
So far it seems:
Inspect/adjust brakes
Lube
Housing gasket
End Seals
Also:
Disc swap will need a new tie rod or sleeves. Do the sleeves have any sort of downside?
Better choice than a locker for most, but if you still plan to wheel it in any difficult situations then a true locker can pay for itself. However, for most of us a limited-slip is the better option. So yes, just rebuilding the existing one is a very viable option.
You know for sure you have a limited-slip? They were options from Ford, but not everybody got one.
So far it seems:
Lube
Housing gasket
End Seals
You forgot perhaps the most important rear wheel bearings.
Unless you know for a fact that they've been changed, I would just add them to the list and do it no matter what. If you don't know their history, then you have to assume they're original. Even if you have less than 100k miles on your EB, they're now over 40 years old and so is their grease. Time for new ones either way.
And since you're in there anyway... The best way to change the fluid and the only way to change the gasket is to pull the axles out and then pull the center section. So "while they're out" go ahead and plan to spend the 100 bucks or so to replace them. Probably a little more these days, but still not too bad for the results.
Not that I can think of.
Maybe a little coating of grease or dusting of paint to keep them from rusting, but that's about it. Not much paint though, or the precise fit kinda goes out the window.
