Axle Shafts the Same?
Chief Master Sergeant
Retired U.S. Air Force
Converting the Dana 30 to a Dana 44. Are the axle shafts interchangeable? I did a search and came up empty.
No
The inner on the 30 has 27 splines
The inner on the 44 has 30 splines
But the outers are the same
cldonley
Robinson, TX
I may be crazy, but I think that is the most significant difference between the two. I remember reading that the 30 represents the diameter of the 30's shaft and the 44 likewise. Maybe in mm? Of course I could be having a senior moment! :-[
jim3326
Appleturkey
Other than the shafts being weaker. I would think it makes more sense to upgrade than risk tearing something up if/when it breaks.
Jim W.
welndmn
Minus a few brake/hub parts, not a lot of dana 30 parts swap onto a dana 44
You need new axle shafts.
Yeah, just plan to use the ones coming in the donor. I just replaced the joints in the axle shafts is why I asked. No worries. Joints are reasonably priced.
Just a heads up on front axle joints. They are the most highly stressed joint in the truck. When they fail it is usually violent, taking out the ears of the shafts as well. This joint is very touchy about quality. The bargain parts store joint will fail much easier than a good Spicer joint will. Running cheap joints will probably cost you more money in the long run since the shafts will need replacing when the cheap joint fails. Only run good Spicer joints in the front. They are already a little bit undersized and need all the help they can get.
Thanks brother. I always get Spicer. Haven't tried to source them here in Albuquerque yet. Thanks again
moses_m
Sargeant doing the same upgrade as you. What tie rod and drag link are going to go with, stock or are you upgrading?
