Hey guys,I finally got all me lites working except the reverse lites. Call me stupid but I want to check the switch. My question is where is it,on the column,or someware on the trans. I have a C4 if that helps
C4 has the reverse light switch on the transmission. Where the shifter attaches.
Many aftermarket shifters delete the factory safety/reverse light switch.
Often swapped in transmissions are done and never get around to doing the couple of wires. If this was the case the stock 3-speed reverse light switch is (was?) on the steering column. Under the hood near the firewall. Where the shifter arms on the column change to rods going down to the transmission.
Here is a photo showing the reverse switch on mine. I have the 3 speed on the column.
The switch that I have is only 2 wires. Incidentally, I also have the square plug, so I think they put the wiring for both on it. I know my truck was and always has been a 3 spd.
The 4 pin connector is on all Broncos from 1973 to 1977. That way the appropriate reverse light switch could just be plugged into it no matter what transmission was installed.
