HeroesNeverQuit
- May 21, 2024
- 2
So we ordered all new replacement gauges for a 74 bronco. Originally, the gauges all work. After replacing them, only the voltmeter was working but this was to be expected as new lines were ran.
Originally we thought IVR. Replaced it after testing because it wasn't outputting 5v. Install new one, same problem. Decide to bench test. Ivr is fine. So then we checked each gauge one at a time installed in the cluster as well as the old one.
Oil pressure when installed alone, works. Install water temp? Oil gauge stops working, the water temp works when not installed but then when tightened into the cluster, stops working and no more 5v. It was the same for the fuel gauge.
Now, the old fuel gauge still works and when installed fully the oil pressure still works. My guess is that something in the two new gauges is causing an issue. I'm thinking it's a manufacturer defect since we haven't done anything else to them.
Our old water temp gauge does the same as the new one but we know it was working when originally removed. I dropped it and potentially broke it.
A ground has also been added directly from a good location to the grounding screw at the IVR.
Is it possible we got so unlucky and get two out of four gauges dead on arrival?
