slowRoaner
Was all ready to fire up the newly installed efi, poured in the coolant, and two streams started leaking out of the intake manifold. One on the front passengers side just behind the thermostate housing between the head and manifold, and the other on the rear driver side. I have read about the faulty 1250 gaskets( http://classicbroncos.com/forums/showthread.php?t=226843&highlight=intake+manifold+coolant+leak) , and im pretty sure that is what I used. I torqued the manifold to spec and used plenty of orange rtv sealer when installing. Should I retorque and fire it up for some heat, or should I just assume its leaking internally as well and replace all the gaskets again with 1250-S3 ??
