cootvon
my rpm's are all over the place. some days i'll get 10 miles down the freeway, pull off on my exit and the darned thing is still jacked up. if i were to turn the truck off, back on... let the choke rev it up, then tap the gas.. usually it will go back to a smoothe idle, but 90% of the time it doesn't.. it stays high until it decides when it is good and ready to go back to normal. It also will not work at all sometimes..giving me a lower than normal idle..but then an hour later i can hop back in it and it revs up again.
so is it not adjusted correctly, or is it failing or both? i assume that it is sticking both "open" and "closed" but i'm not really an expert obviously on how these things work. could rpm's all over the place be something different? i assumed that the choke is the only thing that can hold the rpms that high...and then be normal the rest of the day. heck i could probably drive the 15-20 miles to work in the mornings without touching the gas pedal!
btw.. it's the edelbrock 650 cfm performer... could it also be a sticking carb?
thanks for any insight
Jeff
Jeff
