Ok I'm rebuilding front Dana 44 with an existing Chevy disk conversion. When I tore it apart there was no snap ring on either ball joint. Replaced ball joint and there is no room to get a snap ring in either ball joint. Shop manual shows the snap ring on the lower but it's not sticking out enough. Upper has almost enough room to get a ring on but the ball joint is bottomed out like it should be and I would have to take the ball joint out and grind some material off to get a ring in. The joints are spicer from jbg. Next, I torqued the ball joints on the inner c's and pass side felt good but driver side was real easy to turn the knuckle. I looked and the adjuster nut was a lot farther in to achieve the 40 ft/ lbs torque. So I loosened the adjuster to the same depth as pass side- not torqued- then torqued upper nut until I got about the same feel as pass side. Confirmed this with a pull scale-20 lbs- which is within spec. Does this sound ok? The ball joints appear to b pressed in right - I used a ball joint press. Maybe the driver side knuckle is spread open a little. Am I ok without a snap ring? Thanks for any advice. Bob.
