I would. I prefer the full 12v to a resistor myself (simpler) but either way works. You may not have a choice though as which coil you use may depend on the rest of the ignition anyway.
Do you know if it's got points or Duraspark or something else?
(edit: sorry, I saw you mentioned Pertronix but went out of my head there for a minute.;D ) But do you know what model it is? Could be an Ignitor I, II, or III.
With some you can use certain coils with 12v and others need the resistor still.
You can read about some of them here of course:
http://www.wildhorses4x4.com/category/broncoperformanceignition
This one needs a resistor with an Ignitor I, but not necessarily with an Ignitor II:
http://www.wildhorses4x4.com/product/Flame_Thrower_II_Coil_Black
This one should be ok with 12v with either Ignitor:
http://www.wildhorses4x4.com/product/Flame_Thrower_Coil_Black
If going for the gusto, get an epoxy filled canister coil (as opposed to oil-filled), or E-core coil if the rig is going to be run hard and put away wet, or heat and vibration is much of a concern.
We don't stock that type, but can order them. Hopefully if enough people want them we'll bring them in for regular inventory. I've run them and never worried about overheating a coil, or having a leaker after that.
