The bottom plate is actually threaded, so there is no washer and nut needed.Looking at the photo that TNcowboy posted, looks like the body mount is missing the proper washer and nut.
@Comemonday71 is actually correct here. There should be a washer and a nut. Here's a picture from the Baja listing on BATThe bottom plate is actually threaded, so there is no washer and nut needed.
Very common misconception, so don’t feel bad.
But production Broncos did not use washers and nuts on the bottom of the body bolts. Maybe the Baja did, but not plain ol' production Broncos. Certainly none of the Broncos I have had used washers and nuts. I know, because it always looked strange.@Comemonday71 is actually correct here. There should be a washer and a nut. Here's a picture from the Baja listing on BAT
And you forgot. They are all rusted on by now and will require a sawzal or other approriate cutting tool if you ever want to get the buggers off.No. The Baja Bronco did not use nuts and washers underneath. Broncos used a threaded nut washer unit for the lower number 1 and 2 mounts . If you've ever seen a nut on one it is either a) aftermarket washer and nut on a bolt because someone has put on new body mounts and hardware or b) someone rolled under a Bronco on a creeper and said "Darn - the body almost fell off get me a nut and washer and I'll zip it on and save the day,"
I think they would distort if that happened. They have about 1/2" of threads or slightly more - I have one here at my desk since replying earlier. I bet it's folks getting nervous and not understanding they are a threaded unit. I'll post a pic.I wonder if any assembly line mishaps ever happened necessitating a quick fix?
Maybe someone over-torqued them on a particular model and stripped out the cones. A quick fix would be a nut and may be even a washer.
The first bronco I ever saw that had nuts was my 71 the first time I crawled under. I thought it was strange that it had nuts (no washers) and figured one of the previous owners had installed them after they panicked seeing just exposed threads coming through.
I have seen quite a few others since then however.
Yeah, they lock together and "click" when so. And become even stronger when that upper collar snaps on the lower piece we are talking about. Here's some pics of an original. I try to use these in my restorations and often spend lots of time freeing them from one another.
How about........ The new guy at Ford in March of 71, couldn't get the bolt to drop all the way in, so he grabbed his drill, with 3/8 bit and drilled down thru there, knocking out the threads at the bottom ....thinking someone else was doing the nuts n washers later on down the line. He got thru 10 or 12 trucks and then..... Oh crap...here comes Bart....the super....he took that boy aside and said... "look here....now these are threaded, son.... you take these nuts and washers here in my hand and you personally check which ones you did this to...and install them on those Broncos,,,,,now!"wouldn't put it past em
Yes, Andrew. I like the original body mounts too. When the male /female are pressed together, it's a stronger mount than the aftermarket bolt and sleeve it would seem. I have carefully removed them, bead blasted them and had them re-zinc plated . Someone needs to repop them as the originals!...Yeah, they lock together and "click" when so. And become even stronger when that upper collar snaps on the lower piece we are talking about. Here's some pics of an original. I try to use these in my restorations and often spend lots of time freeing them from one another.
You are right not great for the moneyhttps://bringatrailer.com/listing/1967-ford-bronco-49/
Has anyone looked at this one? It seems crazy high. That ecoboost build seems to have people ignoring the paint quality. Cool bronco but 92K, as of now, for something that needs to be stripped and repainted is just crazy to me.
And didnt sellYou are right not great for the money
