76bronc5.0
- Joined
- Jun 14, 2017
- Messages
- 29
All,
I am in the process of relocating my battery to the driver side to make room for my cold air intake tube/filter on the passenger side. I wanted to get some insight from others on my current plan, which is as follows:
Positive Runs
1.) 1/0 cable from battery to ANL fuse (200-300 amp) to B+ stud on the starter solenoid.
2.) 4 gauge from 3G alternator to 150 amp circuit breaker to B+ stud on starter solenoid.
3.) 2 (or 4 gauge) from battery to additional ANL fuse to standalone power distribution junction. This will be used to provide a “clean” power feed for EFI (1993 5.0 HO EEC-IV) and CD box.
Negative Runs
1.) 1/0 cable from battery to engine block (3/8” threaded hole below alternator bracket on block)
2.) 4 gauge cable from battery to core support
3.) 4 gauge from firewall bulkhead to bellhousing bolt on back of block
4.) 1/0 cable from block to frame
5.) 4 gauge from firewall to block
6.) 4 gauge from battery to standalone ground distribution junction. This will be used to provide a “clean” ground path directly to battery for EFI and CD box.
Ultimately, I am trying to minimize the number of long cable runs from the battery while still retaining adequate circuit protection and providing a dedicated path for power and ground for the EFI and CD ignition box.
Has anyone used an ANL fuse for the main battery feed like I’m proposing? Most battery relocations I’ve seen typically relocate the starter solenoid close to the battery, so that it’s only hot while cranking, and then run a separate charge wire from the alternator back to the battery. I was trying to combine that in a single run but wasn’t sure how the fuse option would work during starting.
Lastly, how are others providing clean power and ground for their digital electronics? Can this be a clean distribution junction like I’m proposing or should both of those items have dedicated runs back to battery? Also, what about switched 12v power for the EFI and CD box? I currently have the pink ignition feed wire from my AAW classic update serving as my key on source (fed from main fuse panel, which currently receives power from the B+ terminal) but not sure if this needs to be repurposed to act as the trigger wire for a relay that then feeds “clean” switched power to the EFI and CD box? Looking forward to the discussion and thanks in advance.
Positive Runs
Negative Runs
