casadejohnson
Bronco Alchemist
- Jan 21, 2005
- 3,587
Is there anyplace that you can purchase a cable and sheath that would work as a replacement for the ones in the BC Broncos EFI kickdown setup? Mine is almost new but it is seized up inside someplace. My setup was working well but then it stopped kicking down. I found that the cable was not moving in the sheath anymore. Removed it and tried to lube the cable up with no luck. It looks like the cable shifted from where I had it routed and dropped against the header. The plastic on the outside melted and the cable sheath is extremely stiff in that area. I'm guessing the inner sheath melted as well and thats why the cable no longer moves. I hate to buy a new one since the cable is the only problem but I can't find just a cable and sheath other than bike stuff and that all appears to be too small for the cable ends in the BC setup. I just discovered the problem tonight so I have not had an opportunity to call BC yet but I think I recall that they only sell it as a kit ( From another thread ). I'll buy another if I need to but thought I would ask before I go that route.
