Green_Bastard
- Joined
- Jan 4, 2014
- Messages
- 261
Has anybody gotten this blank dash from BCB recently and found inaccuracies in the description as well as fitment issues? I got one about two months ago and have had nothing but issues since I started trying to mount it this weekend. I did inspect it when I received it and it looked good but the problems are not something that I would have noticed until actually trying to install it and of course its too late to return it at this point.
In the description it indicates that all you need to do is prep and paint. I've found that to be far from the truth. I realize that every Bronco has slight differences but these problems are with the design and quality of the product itself. I'm extremely disappointed and not sure how to handle this at this point.
Has anyone else had similar issues?
- The description indicates that it has studs incorporated for the glovebox hinges but mine does not so I guess I have to put ugly holes in it.
- The spot welds are popping lose in various places and before you ask, yes, I'm being gentle with it.
- There is no provision for the L brackets that attach the dash to the kick panel so they need to be trimmed out.
- There are tabs welded inside where the L brackets sit that need to be removed.
- The notches in the top of the back side of the dash are not deep enough so they need to be trimmed about 3/4 inch.
- The built in defrost chute extends down further than the original and interferes with the center bracket that sits behind the dash so the center bracket needs to be trimmed as well.
- They interfere with the top inner edge of the door post so something will need to be trimmed there as well.
- Last but not least, the glovebox opening is about an 1/8 inch larger top to bottom and side to side than the original meaning there will be a larger gap around the glovebox door when closed.
