BCBroncos Blank Dash Issues
Green_Bastard
Has anybody gotten this blank dash from BCB recently and found inaccuracies in the description as well as fitment issues? I got one about two months ago and have had nothing but issues since I started trying to mount it this weekend. I did inspect it when I received it and it looked good but the problems are not something that I would have noticed until actually trying to install it and of course its too late to return it at this point.
  1. The description indicates that it has studs incorporated for the glovebox hinges but mine does not so I guess I have to put ugly holes in it.
  2. The spot welds are popping lose in various places and before you ask, yes, I'm being gentle with it.
  3. There is no provision for the L brackets that attach the dash to the kick panel so they need to be trimmed out.
  4. There are tabs welded inside where the L brackets sit that need to be removed.
  5. The notches in the top of the back side of the dash are not deep enough so they need to be trimmed about 3/4 inch.
  6. The built in defrost chute extends down further than the original and interferes with the center bracket that sits behind the dash so the center bracket needs to be trimmed as well.
  7. They interfere with the top inner edge of the door post so something will need to be trimmed there as well.
  8. Last but not least, the glovebox opening is about an 1/8 inch larger top to bottom and side to side than the original meaning there will be a larger gap around the glovebox door when closed.
In the description it indicates that all you need to do is prep and paint. I've found that to be far from the truth. I realize that every Bronco has slight differences but these problems are with the design and quality of the product itself. I'm extremely disappointed and not sure how to handle this at this point.
Has anyone else had similar issues?
COBlu77
Arvada, CO
Yep, same experience, but mine was apparently some early batch that was thicker at the top and my dash pad wouldn't fit. I discovered this after I had done extensive work to it to fix the flaws and had it powder coated. I was told I could send it back (on my dime) and that they didn't anticipate that people would be doing restorations with that dash.
centex77
Can’t say I’ve had those issues as I got a completely blank dash. I did notice a couple of tabs missing. I can’t speak to figment as I’m doing an all fiberglass body so that might be some of the issues. Do you have pictures of yours mounted? Might help me with some questions I’ve got on mine.
Green_Bastard
Green_Bastard
Some how I created this thread twice and there are different responses on each so I'll update both with this info. I talked to Jason at BCB today about the problems. There are some differences in how the new dash should mount that I was not aware of because no instructions were included but some of the problems are still valid. Jason indicated that it sounds like the dash I received wasn't built properly especially since the spot welds were popping lose. He is sending out a new one to replace mine and will inspect it before sending it out. During our discussion, he was nothing short of top notch in his customer service and I really appreciate it so a big shout out to BCB.
AZ73
Next time you speak with Jason, ask him to post the instructions on his website. I have the blank, have done extensive work to it and it's currently in paint without me first testing it (my bad). When it comes back, I'd like to know how to install it with as little problems as possible. Thanks.
JefeAZ
Tucson
I just ordered the stock cluster/offset glovebox dash last week and they are welding it up today. Hopefully your call with Jason made him pay close attention to mine!
JefeAZ
Tucson
Got mine and it looks great. Ill get a closer look at it Sunday when we mock it up
Someone enlighten me again, what are the two holes for under the column?
Green_Bastard
Green_Bastard
Two of the column mount bolts go through the two holes
sprdv1
REBEL
Glad he got you taken care of...
AZ73
Mine didn't have welded on bolts for the glove box door. I decided to drill holes for bolts so I had more flexibility to adjust the door.
JefeAZ
Tucson
Got some close up shots of the dash and temporarily mounted it. Seems to fit great.
Green_Bastard
Green_Bastard
I recently got my replacement and there are some slight differences and it looks like the welds were beefed up over the spot welds. I did a test fit and it’s perfect, or I should say, perfect for a 47 year old Bronco.
