Berg Build
Casey835
Just had a chance to read your thread, I bought a hard top from that guy a few years back. I got the tour of his shop also. He is a very nice guy. His son use to be on here a while back but I don't think he messes around here much anymore. Nice build by the way.
Sent from my iPad using Tapatalk
Tcb3078
Tcb3078
Charlotte
Took the body off...
Tcb3078
Tcb3078
Charlotte
Touched up frame. Installed starter and passenger header
Tcb3078
Tcb3078
Charlotte
And more for viewing
Tcb3078
Tcb3078
Charlotte
Installed gas tank and plumbed for fuel.
Anyone have measurements for how high the tank can go for a 2" body lift?
Tcb3078
Tcb3078
Charlotte
And some more
Tcb3078
Tcb3078
Charlotte
Loaded up to get exhaust ran.
Tcb3078
Tcb3078
Charlotte
Exhaust was run. Just need to clean it up a bit. Then going to paint with vht fireproof paint.
Also installed a.c. compressor.
bronkenn
Bronco Guy
Southeast Ohio
You aren't going to like those downturned exhaust pipes if you want to keep your truck clean, they will dust up everything and everyone around you.
bronkenn
Bronco Guy
Southeast Ohio
Looks really nice. How do you like the new gas tank? I was thinking of getting one of those adjustable height tanks. Ken
Tcb3078
Tcb3078
Charlotte
Plumbed up half the power steering and cooler.
Can I use AN fittings and line on the pressure side of the powersteering.
Tcb3078
Tcb3078
Charlotte
Painted the exhaust cross member, and went ahead and painted the exhaust with the vht flameproof paint.
Crawdad
I used the same oil cooler, it just seems like a perfect fit. I would highly suggest filling it up with power steering fluid. I went to these extremes to reduce the amount of air that can build up in your lines. Nothing worse than a PS pump spewing fluid all over everything when you go to start it up.
Tcb3078
Tcb3078
Charlotte
I filled her up today.
Tcb3078
Tcb3078
Charlotte
Been slowly collecting parts and waiting for weather to warm up. Finally sanded the bottom of the tub last weekend for raptor, going to spray this weekend.
Got my gauges too!
Tcb3078
Tcb3078
Charlotte
Laid tintable raptor
