sandguy356
Very much wrong. The valves angle right into the stock valve pockets just like they were engineered to. The special pistons are for when you want to run silly high compression ratios for all out racing. When you get into the pop-up pistons then you will want the special ones just for trickflow heads.
Like this?
http://www.jepistons.com/Catalogs/Automotive/Ford/302_flat.aspx
Thats a flattop piston, no dome. I was just trying to make sure the guy doesn't buy a set of heads and find out he needs pistons too.
