Best aluminum heads
mkaenel
La Costa, CA
So it is time for new heads and I might as well go aluminum.
Any thoughts on the best heads to get?
This is going on a carburated EB.
Thanks,
Matt
broncnaz
Kinda depends on what each of us happens to be running. I really like my TFS heads. They work great on my 302 and will be perfect if I ever go to a 351W. If they would have offered 1.90/1.60 valves I would have gotten them instead of the big 2.02 valves I have now. I have a set of world products windsor jr cast iron heads that I plan on using in my 71 one day I think they will be very good as well.
But seriously most of the heads are pretty close in performance. Even then most of the differances wont be realized in a bronco application. It all depends on what you want for compression ratios and valve train options. I would suggest 1.90/1.60 valves and 60 cc or so combustion chambers also beaware some heads will come setup for roller cams others for flat tappet. Just make sure you pick the correct p/n.
How wild or mild is the engine going to be?
I ran a set of Trickflows for 10 years and liked how they ran from idle through 6000 RPM with a mild cam. Carbed and EFI, didn't matter.
Small displacment mild engine will be happier with smaller runners. AFR 165. As the displacment and cam increases, so should the heads.
addicted
Broussard, Louisiana
Yea, if you are choosing heads to put on an existing motor, then calculating the CR with the pistons you have is pretty important. I have heard great things about AFR heads. Also Edelbrock, Twisted flow, Dart, and others. Just pick the valve size you want and combustion chamber size that gives you the desired compression ratio. I already have forged aluminum pistons that produce 9:1 compression with a 64cc head so Im choosing Ford Motorsport aluminum GT 40 Turbo Swirls. The offer them in 58cc and 64cc so they should be perfect for a peppy low rpm street 351
ken75ranger
Troy, NY
I used graphite coated ones. They let the aluminum and cast iron expand at different rates according to my machinist.
sandguy356
Holland, MI
As far as heads go, I really like the world products windsor jr. for under a 351 or windsor for a 351+. Good aluminum castings for a good price and all the valve train is available at most speed shops.
Head gaskets, go with a Cometic or Titan, mls head gasket. They are more $$ than fel pro or mr gasket, but they are really good gaskets and will work well. mls is the gasket design that most auto makers use on production cars and trucks with aluminum heads/iron blocks.
I don't think you can use a Trick flow head, due to the fact that trick flows use a specific piston design for their small block heads.
Very much wrong. The valves angle right into the stock valve pockets just like they were engineered to. The special pistons are for when you want to run silly high compression ratios for all out racing. When you get into the pop-up pistons then you will want the special ones just for trickflow heads.
The last summit catalog showed some MLS gaskets for a lot less then the Cometics. I ran Cometics simply because that was all I could find when I did mine years ago.
12-Pack Jeff
La Mirada, Ca
let me just ask this.. you say "might as well go with aluminum heads" why so? I was always told that a properly setup iron head will always out perform an aluminum head. I'm merely asking for curiosity not to incite a debate of alum vs iron. but I'm curious to see what everyone has to say.
broncnaz
While properly setup Iron heads can be good I dont think they will ever be as good as aluminum heads. There are many factors here. 1 is cost by the time you get iron heads setup to perform well you could have bought aluminum heads that will be as good or better right out of the box for less money. Thats not to say that there are not good iron heads availible but still compared to the aluminum heads they dont put out the numbers.
Aluminum dissapates heat better than cast iron so higher compression is easier to run without detonation or pinging and usually you can still run pump gas.
Aluminum heads can still be ported more and usually have better valve angles for better flow.
now in most bronco applications the full out heads are not needed and wont really be a benifit.
Way back when I decided to go to aluminum heads I first looked at getting my stock heads setup like I wanted which was bigger valves and adjustable rockers. The cost for machine work and parts was going to be almost the same as it would for a set of new aluminum heads and the new heads were going to flow way better than the stockers so I went with the aluminum heads.
Way back in the day many people were scared of aluminum heads because many early engines that had then tended to melt the heads and these were stock engines.
I have a good set of cast iron windsor jr heads that I think are perfect for bronco applications they are better than stock heads and a little cheaper than aluminum and setup the way I want.
If cast iron heads out performed aluminum I doubt there would be such a big aluminum aftermarket and so little of a cast iron market. Thats got to tell you something right there.
TonyPDX
One big advantage is the weight savings. 50lbs off the front end is always good. But, you are technically right that that an iron head will make more power if they have identical design, CR, etc., because they retain more of the heat in the combustion chamber. I doubt it would be enough to out weigh the weight penalty however. In reality aluminum heads are designed for performance whereas OEM heads are optimized for emissions and MPG.
I would buy aluminum heads.
Anyone need a cheap set of mid-nineties 5.8L marine heads, cheap?
Tony
broncnaz
I've seen some dyno tests on supposedly the same head castings in iron and aluminum that showed very little power differance beween the heads the aluminum heads still made slightly more power across the board. So that in itself can sort of disprove the heat factor. The cooling system controls the temps to a near constant temp no matter what the head material. but yes I can see where aluminum could make less powwer since too much heat may be transfered.
