I just wanted to post an update to my problem. I received the Holley 1" spacer today and decided to put it on. Heeding jckkys's advice, I tapped the egr hole in the manifold and plugged it with a 1/2" bolt that I cut off and ground smooth. I put on the Holley spacer and started her up and it wouldn't run. I did finally get it to idle, but it definitely wasn't right. So, I decided to reinstalled the original EGR spacer after I cleaned it up good. I used two thin gaskets at the manifold and the 1/4" gasket between the spacer and the carb. It runs like a top now! Idles smooth and runs great! I've had this truck for almost a year and never had it idle correct, even after changing the carb and gaskets a couple of times. I guess the third time really is a charm. I am so happy with the results! I appreciate all the feedback on this forum! Oh yeah, if anyone needs a 1" Holley spacer 17-72....I have one to sell....cheap....lol. Thanks again!
