Best Drill Bit?
JohnJohn
Richmond
I started to install a set of pinion shims last night to try and eliminate a 55MPH drive line vibration. The bolt holding my Cage leaf pack together is smaller than the 3/8's bolt that came with my kit.
I broke several drill bits trying to resize the hole in my leaf springs.
I am sick of cheap drill bits. Any recommendations for good ones?
Clint
Grand Junction, CO
lots of cutting oil and some serious time to drill them out, helps if you have a grinder to keep an edge on the bit... My advice would be to use a heavy washer on your spring perch to neck down the hole, or im pretty sure you can get spring pins with different size heads eliminating the need to drill the pack.
Steve83
It's not the drill bit that's the problem. It's that you're drilling a VERY hard/tough material only slightly larger than the existing hole, so the bit digs in too quickly, grabs, and shatters. You need a bit that can't dig in that fast, like a UniBit (stepped bit). Using a normal spiral bit in a drill press would also work.
But to answer your question, the best drills might be Snap-On Thunderbits. For ~$10/ea, they oughtta be!
<-Clickable
Kyle.malone
Norman, OK
I get Mibro drill buts from Tractor Supply Company and they work better then anything I could buy at Lowe's or Home Depot. They cost more, but they sure do work better. Just make sure you get the ones for metal.. They offer them for metal and then for Wood,PVC.
JohnJohn
JohnJohn
Richmond
I think I was drilling to fast. My plan was to pull the leaf pack off the truck tonight and try to drill the hole on my drill press. Taking my time with cutting oil should also help.
The Cage spring uses a 5/16 bolt and the round head is too small for the 9 inch perch hole.
The new Wild Horses shim uses a nice 3/8 bolt with the correct size round head.
I would rather use the larger 3/8 bolt. I am willing to do whatever it takes to drill the pack. (I say this now but let’s see how it goes tonight)
Dave
Buy a cheap HF drill index. Start small and work up. Put plenty of oil on them. Drill press works the best. Pitch them in the trash when you are done. Springs are very hard as stated. I dont know of any bits that really work well. Even in a mill.
needabronco
Prescott/Farmington
I buy drill bits in quantity when I have any project, so I've been putting some serious thought into a quality set off of a tool truck myself! For now I've found the Bosch bit's from the hardware store seem to last the longest.
I too have to seriously wonder why your trying to drill out the leaf packs. Change the perch or find a shim/washer to take up the difference in size.
bax
Old Member
Use a masonry drill bit. it is carbide tipped and will cut the spring steel. Even better if you have a way to sharpen the bit. Some oil and pressure and you should have some luck. A cobalt bit will also work but the masonry bit is way cheaper.
Nightmare Bronc
Like Bax said I have used masonry bits and had very good luck. Just be sure to keep them cool the carbide tip is soldered on.
RIbronco
Costa Mesa, CA
How about getting a 5/16 hex head bolt and grinding the hex head to a mostly round head that fits into the perch.
Spin the bolt by putting the threaded end into the drill, then apply the grinder to the hex head. Grind peaks off of hex until it fits into the perch. This should take about 5 minutes per side.
Let us know how the shims worked for the vibration. Mine is similarly afflicted.
bax
Old Member
Uh. allen head bolt should work. It is round. get a grade 9 if you can find it. Also most parts houses have spring bolts
dead road
Ridgefield WA
I have drilled alot of holes in steel and stainless with the rigid bits at home depot. I was really impressed with those bits compared to any of the dewalt, milwakie ect bits a home depot.
JohnJohn
JohnJohn
Richmond
Thanks all for the help. I went with new bolts vs drilling and got the truck back together. I went for a test drive and the vibration is almost totaly gone now. I can barely detect it at 70 MPH.
I want to put some miles on it before i change u-joints. The ones in the shaft now only have a few hundred miles on them.
Tomdee
Staten Island
I have opened spring bolt holes in the past,an old machinist tip is to use Permatex super 300 sealant as a lube and use hi speed drill bit. Try it it worked for me!!
Tom D.
