Best Drill Bit?
prosys1
Victorville, CA
IMO, as a machinist, you need an M42 cobalt drill bit.
I saw above a link to McMast-Carr. Easiest, and not too expensive.
Carbide tipped drills are just going to chip on you and I doubt you have the correct grinding wheels for your bench grinder to sharpen them.
You need some type of lubricate to not only help with the drilling, but cooling the bit as well. We use WD-40. Unless of course you have some sulfur oil. Motor oil is the last choice, since in can actually use the heat your generating and harden the spring further.
You need very slow rpm on the drill press with heavy feedrates (almost enough to stall the drill press).
Line up the hole with the bit while the drill press is off, then clamp your spring down.
Then start drilling. If it grabs, which it will, back off and try again.
Good luck.....
Pa PITT
Stephenville TEXAS
Some good advice here .. I've ruined more good drill bits than I care to admit. I sure fine my drill press helps not break as many. I would have just gone to town an got another spring center bolt the correct size. Since the 1st one lasted 30 years.
Airborne69
Moorpark, CA
Its all about the Cobalt bits...the cheapo ones will only have a thin coating. but the more expensive ones tend to last a while longer.
bigmuddy
Marthasville Missouri
I purchased a drill doctor a few years ago, one of the best purchases ever after a good grinder and welder. I also used an grade eight allen head as well.
Ben
