Best engine Break-in Techniques
redvettemike
We have rebuilt the 302 engine out of this stock '77. The engine is all stock, .030 over with new pistons, bearings, cam, head job, .010 turned crank, etc. We will try to crank it soon. What is the best way to prepare for the cam/engine break-in? Is there a way to get the oil pump to pumping (seems like on a Chev or Olds we used a drill to spin it over). It has Comp Cam break in oil in it. Once running how long before changing out that break in oil?
Tks for any guidance.
broncosam
Get one of the tools/shafts that will fit the oil pump, pull the distributor and pre-lube the engine. This tool/shaft is used with a drill to spin the oil pump.I've even seen some made with old oil pump shafts with an extension welded on. I would do this before I just started cranking the engine to get the oil up where it needs to be for the initial start.
turbotim2
____________
Just pull the distributer, the pump shaft should not come out as it should have a retainer on it, put a 1/4" socket on your drill with an extension and crank away counterclockwise.
You will feel it when the pump starts making pressure.
bobscott
Per my rebuilder... Prime engine with the tool. I got one for somewhere around $10 that has a collar to keep it aligned. Run your drill in reverse. Fire the motor and vary RMP from 2k to 2.5k for 20 minutes. Run 500 miles of normal driving. Change break in oil, he recommended a higher zinc oil for normal oil after break in.
Fairlane514
Houston
If you use the 1/4 inch socket make sure you tape it to the extension or secure it to your liking so it doesn't fall off.
I like to fill the carb bowl with fuel through the vent tube and make sure I'm getting discharge through the squirters. The faster the engine fires with minimal cranking the better.
Also check to make sure you have power to the coil in the "on" and "start" position before you try and start it.
SteveL
Huge chevy guy
Hawthorne ca
I think you need the zinc for the first few oil changes. I use regular oil with the lucas break in additive.
blubuckaroo
Grease Monkey
Ridgefield WA
Whenever breaking in a new cam, the most important thing is to bring the engine up to speed as quickly as possible, without a lot of cranking, blubbering, dying and such. I like to the fill the block with coolant as much as possible before installing the thermostat. Fill the carb with fuel. As already stated, either zinc additive or break-in oil and prime the oil pump. Static time the distributor by aligning the timing marks on the balancer and connect a continuity tester to the distributor. Have a plan to either have someone sitting in the driver seat or another person hand throttling till the idle screw can be adjusted to keep the idle between 1600 and 2000 RPM for twenty minutes or so. Some like to vary that speed up and down a bit but I don't think that's important.
The smoke, sound and anticipation of starting a new motor is one of the things we live for. Have fun!;)
Helps to have multiple people around too, so that while you're holding it at 2000 rpm or so, the others can look around for leaks of any kind (fuel especially, but oil and water come to mind too) that might otherwise distract the holder-of-throttles.
Another thing they can do is verify the ignition timing is on the money. I know you can get it pretty darn close by hand, but with those nice shiny newly coated exhaust manifolds, the last thing you want is to run it at 2000 rpm for an extended period with retarded timing.
I always use plain water in the cooling system for the first startup. Any leaks or follow-up dismantling can be much easier with just water.
One more thing that's not necessary, but helpful sometimes, is to just go ahead and run it for 10 or 15 minutes then shut it down to cool. Then finish the break-in a little later.
Like I said, not needed, but gives you a break, and new engines actually seem to like a heating AND cooling cycles, rather than just one long hot cycle.
Have fun.
OH, and wear ear plugs!
DJs74
Unless you filled the block and intake manifold with water / antifreeze ahead of time, you'll want to have a couple of gallons of water handy to top off the radiator after the thermostat opens. If the system is already full, then no worries there.
If by some chance you have a leak or any need to shut it down prior to the 20 minute break in period, shut it down from the high RPM... Don't go down to normal idle, then off. It is critical to the camshaft that no idling (600 - 1000) goes on until the camshaft is properly broke in.
DJs74
ntsqd
heratic car camper
Upper SoKA
Leave the t-stat OUT for break-in. It's purpose in life isn't desirable during break-in anyway. A fresh engine is going to build a LOT of heat rather quickly. I don't bother with coolant either, distilled water only.
Put the t-stat in after break-in and before the 500 miles.
Based on ~20 years of part time fab work for a race engine building shop this is my thinking when breaking in a new engine, pretty much exactly what they say and do. There isn't a holy grail RPM to run it at. Oil sprays off the crank & rods and that spray is what lubricates a flat tappet cam & lifter combo. Since the spray pattern varies with RPM what is important is that different RPM's be used and that you don't dwell at one RPM for very long. Never know where the oil isn't going at any particular RPM.
Prime the engine. I use an old points dzzy with the breaker cam & points plate removed and all of the teeth ground off the gear.
The part way thru shut down also gives you a chance to look the engine over and check for any problems. Recommended.
Starting a fresh engine in an urban area at 9PM, NOT recommended.
savage
Bronco Nut
Renton
The first time you turn the key on a fresh motor, is the most exciting and never racking moment. I had mine rebuilt at a shop and they had me use the break in procedure, that the cam company recommended for their cam. Plus used a 30 wt high zinc oil, and a break in additive.
ren71
Heads up! The shaft is notorious for being easily pulled out of SBFs; tons of cases of it falling into the pan and needing to drop the pan to retrieve it or fish it out somehow.
twisted 66
Norcal-Tracy
It is also a good idea but not mandatory to rotate the engine while priming rotate it a little bit at a time. Hydraulic vs flat has different break in procedures, not sure what you have. 30 weight is good oil for break in and after some diving change oil and filter. Some people cut open the filter to see if there is anything abnormal such as excessive shavings etc... Just my.02
