Best headers to run ????
Venom09
Anniston , Al
I am putting in a new 342 stroker motor in a couple of weeks and need to know what are the best headers to buy.
Any suggestions ??????
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
After a month of putting it off, I finally put these Headers in this morning.
It took forever to get the old ones off. These Hedmans slipped right in. I couldn't believe how easy they were to install. Couldn't ask for a better fit.
Just my two cents. There are many opinions about headers.
spixican07
Houston
My Duff's headers are nice. They do barely touch the spark plug boot on the #2 cylinder though.
And my under hood temp is about a zillion degrees :p
jrbronco
if you plan on running full width axles you sould run the shorty headers out of a 5.0 mustang.the long headers will be in the way of the front driveline.just a heads up
Clint
Grand Junction, CO
im running the WH shorty headers.
XT700
Brownsville
I have the Wild Horses shorty headers as well, very easy to install and my exhaust guy commented on how easy it was to connect a system to them.
73stallion
Eugene, OR
i've installed many sets of headers, i think i like my hedman elites as ObscureMachine listed above the best. BC's flanged are nice, WH's are nice, duff's are nice.
irwin
redding
summit free shipping and less money than the bronco venders sounds like a winning combination!;D
Muddypony
I have had a set of Hedmans elites on for sometime with no problems. Fit and finish are great.
broncnaz
I'd consider long tube headers with 1 5/8" primaries for a Stroker got to let that thing breathe. I think that BC's are 1 5/8" and I know that Hooker Super comps p/n 9814 are 1 5/8" they are also fenderwell headers that run outside the frame so it doesnt matter what tranny you run. But if you have shock hoops I dont believe they will work.
Long tube headers will make more torque than shorties. Shorties are usually just a tad better than stock manifolds. I would also suggest getting the coated versions of what ever you buy they look nicer and will last a lot longer when coated.
V
Venom09
Anniston , Al
long headers
Thanks for the suggestions....
Is anyone currently running long headers ?????
If so what is your set up.. I am concerned about the fit....??????
V
Venom09
Anniston , Al
Just looked at the Hedman Elite.... I like the looks!!!!! May be ordering some today
Thanks ObscureMachine for the link
ObscureMachine
World Headquarters
Get the good gaskets (Percy's aluminum). I read what everyone on here said and decided not to use the ones that came with the headers (paper).
If you haven't decided on mufflers yet, here's a thread about some CHEAP FLOWMASTERS. I bought some but haven't put them on yet.
BroncoMark
Irvine CA
If you don't mind cutting the wheel wells the hookers are really nice. They will limit your shock hoop options, but leave plenty of room around the tranny and t-case.
TJK74
Newark CA
Will the full length work if I have dual shock hoops on the front ??????
Yep they will work I was previously running the Duffs long tubes with the hoops and they fit fine. I recently switched over to the BC headers
wildbill
Old Bronco Guy
:D :D :D I would suggest hooker wheel well as you can run any trans and they work well. The part # 9814 your motor will breath good then good luck and have fun.;D ;D ;D Bill %) :cool: ;D
Rob1962
I'm running Thorly full length ceramic coated. They fit fine, no cutting, look and perform great. I highly recommend them. I also recommend the locking bolts.
