I have been working through an electrical problem that started with the starter and that has been resolved now I believe I have a bad resistor wire from the ignition to coil since it will start but dies when it goes to run and I have tested the voltage at the coil when in run and I get 0 volts...so now what is the best option to fix this 1) splice into the red green wire from ignition run to a ballast resistor and run to coil 2) get a coil that works with 12 volts
And run a straight wire to it from the red/green at the ignition and bypass any resistors.. These are the two options I have read about on here if there are more please let me know...
